Do mid 80's through 2005 GM S10/Blazer/Jimmy 2WD vehicles have the same front lower control arms and spindles as GBody's do?
the 2wd s10 pickup, sonoma ,blazer and jimmy use the same control arms. as for the spindles the 2wd s10,sonoma are the same.so am I hearing that the lower control arms are the same but the spindles are not?
Will it lower the front end any by putting on the s10/jimmy spindles and lower control arm? I have an 84ss that I'd like to do the swap and also lower the front atleast an inch or so ?Thanks ahead of time for any help.
Thanks this is the kind of information i needed to know now i have something to go on.!! Thank you Sir, i appreciate itProforged Tall lower ball joints will lower the front end by about .75" and improve steering and handling.
They are $50/each at Summit.
Just swapping over jimmy arms/spindles won't lower the car, but the dual piston 11" brakes will improve stopping.
