Gbody manual swap kit, whats it worth??
84dragcutlass
1,189
1,507
North Vernon IN
What's this manual pedal swap kit worth? Complete kit with the pedals and all the grommets and switches needed.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
depends if you are going to use it all, hydraulic clutch is easier to set up especially if you have headers....
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
Needs a frame plate for the Z-bar, pivot balls, clutch arm rod, neutral safety switch. Key Malibu specific pieces missing include the bellhousing and the clutch fork. Here's a snap of the complete kit:
I might start the bidding at $150 depending upon what you find included. A lot of bits to find still. If you are going hydraulic, you won't need thefork, rods or Z-bar. If you are going T56/T6060, you only need the pedals.
