Congratulations to Rktpwrd for having one badass project in the works!!!
Rktpwrd received 13 out of 24 votes which is 54.2%
Check out his winning ride:
"The Juggernaut" ProTouring 1980 Olds Cutlass
Currently undergoing long term body off build.
455 big block Olds 500hp
Borg Warner T56 6 speed
On air ride with RideTech, UMI, Hotchkis, Global West suspension components
Custom 3" side exit exhaust through the rear quarters
18x8 front and 18x10 rear Foose Nitrous Thrust wheels on Toyo Proxes
Wilwood 4 wheel disc brakes, 14" 6 piston slotted/cross drilled rotors front, 12" 4 piston rear
Narrowed Chevrolet 12 bolt Posi w/ Moser axels and 3:73 gears
Scratch built steel cowl hood, shaved door handles, F85 inspired rear firewall, and many more body modifications
Build thread: https://gbodyforum.com/threads/the-juggernaut-build-thread.55095/
Concept sketch:
Work in progress:
Congratulations again to Rktpwrd for winning the month of July and thank you to everyone who participated this month.
Hope everyone had a great 4th!
Mike
Concept sketch:
Work in progress:
Mike
