Since most of my dummy lights aren't working correctly, I opted to install some real gauges. I purchased the gbodyparts three gauge A pillar pod and when I received it, I gotta say, it was pretty nice, heck they even color matched it to the interior of the car. Once the installation took place the pretty nice went out the window. I am an Auto-meter fan so I threw in some gauges and replaced the existing light for LED's. There is no room in the pod to install the gauge mount on the backside but the fit of the gauges is so tight that I think it is fine. When I bought this I was a little naive, as I thought it would take the place of the original A pillar cover but it does not, you use it in conjunction with the pod pillar and I think that is where the problems come in. You can see that by every place there is a gauge the plastic bows out and does not lay flat on the driver side door side and you can see that at the top of the pillar the gap is just horrible. If you try to fit the pod pillar under the piece that holds your headliner up, it sticks out more than a half of an inch and there is no cutting that side down. I am happy that it came color matched but I am unhappy with the fit of the unit. Not bashing anyone, just a look at my experience with the unit. On the bright side I can now see what is going on with the health of the motor.
