So I have a 79 Monte that I just LS swapped. Car was an all original 35k mile car with the 4.4 and 3 speed trans, for the swap I went with a 2002 ls1 and 4l60e setup out of a trans am. Now that I have been driving the car I’m noticing I can get the rpm’s above say 3200 (unless I’m in neutral or park) I guessing the factory rear gear is the problem since I have a OD trans now. Has always been my plan to change out the carrier for a posi and new gear ratio, I’m trying to figure out what would be a good gear ratio to go with. Car will be a cruiser and will see highway time also I ride on 205/75/14 tires and don’t see myself changing that out anytime soon I want to keep the original look of the car. I plan on going with a setup from quick performance what would your suggestion be for a gear ratio ? Stock LS1 and stock converter with tire size listed earlier.
Thanks !
Thanks !
