Gettin' the shaft....Jeep vs Astro
Ribbedroof
4,900
6,992
Wellston, OK
Jeeps all have a zillion miles, Astros are rapidly becoming extinct in the yards
Pros/cons of each?
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
The Astros need more mods to make them work. The good news is that the Borgeson-style joints on these don't wear that much. Ping Timo22 for more elaboration.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Astro need to be modified but take up less room
Jeep goes right in but vibration damper is just pressed in
both need the column notched to bolt into place
GuysMonteSS
1,449
1,541
Kentville,Nova Scotia,Canada
  • Useful
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
ostrich
310
313
Ontario, Canada
GM put the Astro shaft in a rubber 'Cocoon' as well. They are usually rust free when you pick them. Little nicer to work with. I've done quite a few.
Ribbedroof
4,900
6,992
Wellston, OK
I can buy Astro new GM for under $100...jeep shaft is discontinued, but available aftermarket. I'd rather not put used steering parts on, given nothing is known abiut them, regardless of the source (online or in a local yard)
Seems I remember seeing something about SOME Jeep shafts potentially having a lack of containment in the event of a failure
**Thought I posted this last nite...guess not.
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
Part number on the Astro shaft from GM?
Ribbedroof
4,900
6,992
Wellston, OK
26047898
Lists for 148.88
RGBody87
143
38
Just ordered my astro shaft last week. I’ll have to find the thread about modifying them and weld it up next week. Great time for this post to pop up! I’m following.
