GM's Answer For Pinion Angle Adjustment
69hurstolds
8,195
17,596
Here's a tiny tutorial about what to look for when checking your pinion angle and you're sort of stuck using factory rear upper control arms. Ok, nobody is ever stuck with them, but if you have a car you want to restore and need to adjust it slightly, you can if you can get hold of the UCA variants. Agreed, it's a whole lot easier to get adjustables, but again, this is about something few people probably knew about. It was something I didn't know about until the mid-90s when I went to buy new control arms at the dealership. The parts dude told me that I needed to specify which rear UCA I needed. I'm like, Wut? He said they come in 3 flavors, 0, -1.5 deg, and +1.5 deg. He told me (unverified) that the 0 offset was the common and most-used arm, but they did have some for slight adjustments to the pinion angle if needed. He said it was done by where the rear mounting hole position was placed changing the effective length. Again, unverified, but it's the only way it could work. Obviously, the idea was the -1.5 would push the pinion shaft down 1.5 degrees (longer distance between centers), and the +1.5 would pull the pinion shaft up (shorter distance between centers). And they need to be bought in matched pairs. Or if you just buy one, needs to be matched with the other on the car.
It won't solve every pinion angle issue you may have, if you need a different amount of pinion adjustment. Remember these are compromised engineering solutions for factory junk. Not much adjustment, but they did have a method available if needed. There should be a stamped two-letter code on one side of the rear UCA's. It's either XR, XY, or XZ.
XR equates to zero offset. P/N 10000076. These are the ones I bought because I've yet to get up underneath to check mine. If I found out they're not 0 offset, I'll just rebush the existing ones. Sorry, no picture.
XY equates to -1.5 degree offset. P/N 10001059. You can see the XY stamp here.
XZ equates to +1.5 degree offset. P/N 10001060. You can see the XZ stamp in the pic.
  • Informative
  • Wow
Reactions: 17 users
melloelky
4,161
9,568
mass
" Rembember,these are compromised engineering solutions for factory junk'' 😅😅
I love it
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
I remember there being certain applications/combos that got certain arms from the factory. Think V6 Malibu wagon vs. V8 car w/F41 vs. FE3 w/8.5" differential. I had a sets of two of the three when I was younger.
But, I never knew there were three or that they had specific ranges or stampings/PNs. This is very informative.
pagrunt
9,167
15,345
Elderton, Pa
Checked out the ones on my replacement frame ('86 SS w/F41, G80) & it has XR stamped on them. Looked at the original '81(V6 w/o F41 or G80) frame uppers & they are too pitted to tell.
86Olds442
176
6
Old Bridge, NJ
Thank you so much for this. I bought ones off Ebay many years ago and put them on the car. Have had a vibration since before then but got it much better but not completely gone. This must be it. Anybody know which would have been factory on an 86 442?
69hurstolds
8,195
17,596
The pics I nabbed above for the -1.5 and +1.5 are from current ebay ads. They're wanting 215.00 shipped plus any applicable taxes for each pair!!
It's hard to say exactly which ones you would have from the factory. I was under the impression that XR's were the standard "ideal" part as the pinion angle should have been engineered in. Kinda like the oversize valves and stuff GM used to sell. You would have to know where you were and which one you needed to fix your issue. And again, we're talking factory junk. So you only had a +/- 3 degree swing on where it was maximum using the stock available UCAs.
