Wheels are 16"X 8" zero offset.What size tire are you running?
Front 225/55R-16
Rear 255/50R-16:
Needed a 1/4 spacer in the rear - had to put longer studs in the axles, not a big deal. Front was no problem.
Front:
Rear:
If anyone is curious, these wheels fit quite nice. 19x9.5 with 4 3/8" back spacing. I'm going to have to do some very minor inner fender lip trimming, but very little, maybe a 1/8th of an inch, or less. Just wanted to give folks an update
Wish they had 11" wide wheels, I've always liked these on a gbody.
Yes my car is on eibach springs, 2" drop all round (roughly). I did have to trim a bit of the inner fender trim piece, fender is still super solid. Here is the car with all 4 wheels, everything feels good and absolutely no rubbing:Is your car lowered @ all? Mine is. I'm using 8" wheels @ 4.25" back spacing & I had to slightly trim the lip of the wheel/quarter panel opening. With only an additional 1/8" of back spacing but 1.5" more width, I know the 9.5"/4.375BS combo would NOT work on my set-up *unless the rear end was narrowed*.
*Edit
Beautiful!Rears M/T et streets 255/50 16
Fronts BF G force 225/50 16
Lowering spring all the way around
No cutting
10 bolt 8.5Beautiful!
Same sized tires as me.
Stock axle? If so, did you have to put in a spacer like I had to do?
