Fox80 said:Would you look for a pair of the blazer/ S10 spindles? I don't need the rotors, calipers, or even the hubs for them, finding a 2wd Blazer/S10 up here is like trying to spot a unicorn.
tc1959 said:Drivers side power bucket seat track with wiring connectors and the switch with connector.
G_Body_Enthusiast said:tc1959 said:Drivers side power bucket seat track with wiring connectors and the switch with connector.
you're on the list. not sure if i'll come across it though.
G_Body_Enthusiast said:Fox80 said:Would you look for a pair of the blazer/ S10 spindles? I don't need the rotors, calipers, or even the hubs for them, finding a 2wd Blazer/S10 up here is like trying to spot a unicorn.
i should be able to find them pretty easily.
dottelife said:How much would you sell an compass/temp tinting rear view mirror for with harness
xcookpac said:I need the steel breather tube and rubber that get inserted in the passenger side valve cover. The rubber then connects to the air cleaner by a white plastic fitting which is snapped into the back of the air cleaner.
Let me know.
Many thanks,
Peter
