Hey everyone,
I wanted to introduce myself (Rob) and say thanks for adding me to the forum.
I currently have a 1980 Malibu (originally a Classic w/4.4L V8) that I've s-l-o-w-l-y rebuilt and upgraded over the years. Currently it has a 350 SBC (bored .60 over) which I took out of donor 1986 G30 van (4-bolt main and one piece rear main seal). I had it professionally rebuilt (short block) and I actually do not know the cam profile but it's a slighly lumpy idle and pulls real nice with a Holley 4160 and Edelbrock Performer intake and Hooker Super Comps to Summit Racing dual exhausts (I believe 2 1/2 inch pipes).
I've had the typical G-Body blues over the years (e.g. rotted rear frame rails) and have added some suspension upgrades (poly body bushings, boxed rear control arms, F41 bracing up front) and recently swapping out my TH350 for a rebuilt 700R4. I added the Goodmark 2" cowl to be both functional and accomodate the AC compressor as I switched to a serpentine setup I got on fleabay from a Chevy 1500 series (learned the hard way about reverse flow water pumps and all that fun stuff). CS130amp alternator is the shizzle!
I beefed up the 7.5" 10 bolt rear with a 7.625 F-body Torsen pumpkin and upgraded the axles to new 28 spline. I don't track it or pounce (alot . . .) on the pedals so this amount of beefing up works real well for me. My next project is to pull the axles, replace the rear brake backing plates and wheel cylinders, and swap out current 2.73 Torsen pumpklin with a 3.23 Torsen I tried to use with the three-speed transmission (not a good weekend. . .) .
The doors are still original but alas will need to replaced in the next few years. It's painted GM Medium Stellar Blue (1993) and I get many compliments as she's real clean inside and out.
