Grouchy is getting ready to fuzz
Treyh7042
26
13
Laurens SC
I know long time no post sorry guys just received pcm from a company call warr performance llc ls swap ready vats deleted 3 row radiator and other random parts for grouchy
Treyh7042
26
13
Laurens SC
Keep us posted. The sticker they put on the ECM is crooked. Hopefully the program is good. I’ve never heard of these guys before.
Yep its crooked 🤣 just fixed it peeled right off I guess they got lazy
Treyh7042
26
13
Laurens SC
Forgot to add this is all the features plug and play
This is a Delphi service # 12200411 Powertrain Control Module (PCM) that is used in many drive by cable Gen 3 LS engine swaps. They have been tested on a run stand after programming. This PCM has been reprogrammed as follows:
  • 5.7 LS1 Drive by Cable (DBC) engine with T-56 base tune.
  • VATS disabled
  • CAGS disabled
  • Downstream Oxygen (O2) sensors disabled
  • EGR Disabled
  • Canister Purge disabled
  • Fans 1 (190 degrees on, 185 off) and 2 (210 degrees on, 205 off) enabled
  • Speed limiter set to maximum
