Since I added the 2004R to this beast it is less than desirable in the hills, constantly kicking down, sounds like death is coming soon at 4000 rpm. I could pull through the hills with 2.78 gears without much effort with the 3spd. Would an H pipe help enough at peak torque, which is super low, to be worth the effort? I added the Ignitor 3 module and will add the Accel Supercoil along with an inch taller tire, which won't help the issue. Dyno tests seem to prove torque gains in my rpm range but how much will be gained on a 120hp and 220 ft/lbs motor, any noticeable amount? If I can gain 5 ft/lbs, it is still something. Maybe I answered my own question.
