Hey everyone here is my tiny contribution, as I promised I wanted to make my own halo projector lights because the fake ones that are available. The projector lamps are from The Retrofit Source and they are the Bi=zenon morimoto mini's. I also wanted to make the same for the inside lamps as well because I wanted to have a uniform look!
The ones I am making in this video are for the "dummy" halos but the process for the low/high beams are the exact same I am going to make the exact same cuts using the exact same process hope you enjoy. If you have any questions feel free to ask its all about the sharing!
The projector that I am using for the inside light are the bi-zenon lights from amazon because I am not going to be running high beams in this housing because the outside headlamps will be bi-zenon (both hi/low beam), and the actual halos I am trying to decide if I want the turn signal halo intergrated with the headlight or down low in the turn signal housing......All in all the housings cost me $40 the projectors cost me $25 and the halos will run me $35, for me it's totally worth it if you have driving a vehicle with TRUE projector lamps you know it is worth it!!
PS this is my first speaking video as well as my first time using imovie on my mac!
