HAPPY FRIDAY - CHECK OUT THIS AWD CUTLASS
JAMCAR223
1,853
5,507
Houston, TX.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
That car has been around for almost 15 years!!!!!!!!!!!!!!!!!!!!!!!!
81cutlass
4,649
13,565
Western MN
Its a cool car but the owner is kinda stuck up. Won't tell anyone what he used to make it work. Pretty sure someone asked here and he replied that he's not sharing.
Consensus is that we are pretty sure it uses a TBSS style transfer case and either an s10/blazer or TBSS front diff and s10/blazer spindles and CV axles.
melloelky
4,161
9,568
mass
i saw that in a GM tech mag years ago,i think it was an awd astro based set up.
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
Im still waiting/hoping that the lift post pulls out and goes through the rear window.
  • Winner
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,808
Louisville, KY
One of the YouTube videos he says it has TBSS and I believe Rendevous parts to make it work.
81cutlass
4,649
13,565
Western MN
Ideally, if we lived in Australia we would have gotten the AWD manaro AKA GTO and could have just dropped it in as is.
Could you imagine the sweet 1st and 2nd gen F bodies hitting the autocross if we would have gotten these in the US? Adapt the Holden subframe to a F body and bam.
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
He's lying to throw you off
Was the TBSS even around when he built it???
I know this thing is over 10 years olds
81cutlass
4,649
13,565
Western MN
TBSS stuff existed back to 03 on V8 extended wheelbase trailblazers so the oil pan front diff and stuff existed. Only special part is a larger TBSS spec (8.5"?) front diff which the stock 7.25" small trailblazer diff would hold the power and the AWD always on t-case. Astro and syclone AWD t-cases are the same always on style that the tbss had so it might have used an astro t-case.
The rondezvous part is BS unless maybe he used axle parts like fiero people do to swap 3800's in where they buy random axles out of skyhawk/cavalier manuals and take parts and pieces from various cars.
Its an LS car with a blower so it uses a 99+ 4l60e likely, not sure if a pre 99 60e t-case bolts to a 99+ LS style. I think it does.
Like I say, the only part that really matters is if he cut the hole front subframe out of a s10 4wd blazer and reused the front diff, which doesnt make a ton of sense since the blazer is narrower than a G body, but anything is possible. Could have welded in a 4wd blazer front clip and cut in half to make it the width he needed. A LS in a 4wd requires a pretty custom oil pan (see below) to clear the diff.
TBSS pan, problem here is the diff sits a bit far forward of where it needs to be for a G body, unless he slid the engine back a few inches.
