Hard wiring dash
rogus
309
84
Sounds like a good idea to me. However, you need to do it very neatly and use high quality parts and wire. You need to be adept at soldering and using heat shrink tubing. Do not use cheap insulated crimp connectors. If you need to use connectors, get uninsulated ones and use heat shrink tubing. You also want to be able to have the cluster unplug so that means finding a quality multi connection plug and socket. Could use 2 if necessary.
It will be a fair amount of work but you will have a reliable setup if you do it well. The factory floppy circuit board leaves a lot to be desired. Even when new the resistance to the bulbs is relatively high. When they get old, it really gets bad.
My solution was to go with the Dakota VHX setup. Best $800 I've put in the car. If you can justify the cost. I say do that.
That dash is beautiful!
rogus
309
84
Something that might be helpful:
made this but not sure of how much help it might be to other people.
rogus
309
84
Also, if you need short runs of TXL or GXL wire in different colors Ive been buying stuff from wirebarn.com. Price isnt that bad and they have a bunch of colors.
Thanks for the tip
