I am removing the vinyl top on an 84 Cutlass and would like the cleaner look of flushed glass. Any ideas or pics appreciated if this is even possible
And quarter glass can be reused, again, if custom metal work is done. How much do you want to spend is the real question.In your case, the cutlass has a separated glass from the door , so you won't have my issues. If your stock glass has nice edges & you want to flush it , then metalwork will most likely need to be done to make a nice edge out to the glass. May also need to modify metal to set glass against for proper depth, though a certain amount of depth can be adjusted by using plastic or rubber spacers & thicker sealant. Edges of glass need to be coated with black primer on inside, like modern cars to hide edge AND to prevent sunlight from rotting the urethane sealant.
Lexan or acrylic glass can be used, but it scratches easy. Custom curved tempered glass can be made by a specialty glass shop ( requires a mold), but will be expensive.
Back & front window existing glass may be possible to reuse if custom metal work is done.
Can you expertly weld 20 gauge sheet metal??
Be the trailblazer!!! I think it might look cool, but again, unless it's a "just to see if I can do it" project, I'd probably not do it on a Cutlass. But your time/money/skills. If you decide to do it, you need to take pics and create the story on how you did it. It may just catch fire.have more time than money and yes I can weld. Don't know if I'll attempt it but I do like the cleaner look. Don't care who knows or what they think just want it for myself. Thanks all !!!
I flushed the windshield to cut down on drag and wind noise from the chrome pieces. I welded in strips to raise the windshield ledge and when installing the windshield it sits as high as I could get it to the roof line. I would like to flush the door windows but that would mean making new doors and windows. Without flushing the door windows I don't see the purpose doing the quarter panel windows.
