Having starting issues so it's cranking but not starting. So the belts are moving but nothing. Sprayed starter fluid and put gas in the carb still no start and sounds the same so not sure where to go from here. I checked I have power going to the battery side of the distrubutor. I changed wires and spark plugs. One fusable link that goes to the lights I believe I have to replace but vehicle was still able to start before so not sure if the other one has anything to do with it starting or not? Put a tester to the spark plugs no fire. So I just want to make sure I'm going in the right direction. Any help would be appreciated.
