having trouble connecting brakebooster vac line into carb
palehorse78
26
My brake booster vacuum line has a 3/8 male that should be connected to my carb.problem is the hole in the back of the carb is 7/16. I have searched high and low for an adapter that would connect them but keep coming up with looks like I do not know what I am talking about.am I missing something here?car is an 84 buick regal.motor is is an 305 oles with a Rochester 4bbl carb with electric choke.thanks
palehorse78
26
Re: having trouble connecting brakebooster vac line into car
Is it just that I have not found the right adapted?
zuma83
207
chicago
is there a spot 4it on the intake/valve cover
Bonnewagon
Rocket Powered Basset Hound
10,540
14,217
Queens, NY
I looked around, nothing. Best bet is a junkyard. Fitting looks like this in the picture. The fitting you find may also have several small vacuum t*ts which come in handy for vacuum hookups.
FE3X CLONE
2,714
47
48
Ohio
You need an inverted flare to npt adapter.
How did you measure the 7/16 size?
palehorse78
26
While looking for various adapters. I could get a 7/16 male but not the 3/8 female for the brakebooster line to fit into it
Bonnewagon
10,540
14,217
Queens, NY
See the fitting hiding behind the carb? That's the best one in my opinion.
palehorse78
26
Still having trouble is there a standard size for that fitting I am just going to order online.does 3/8female 7/16male sound right for a roschester 4bbl?
RITTER
2,385
9
38
Hillsdale, MI
Why don't you remove the fitting from the back of the carburetor and install a 1/4" NPT - 3/8" hose barb and run regular PCV/fuel hose to the booster :idea:
palehorse78
26
Sounds like a good idea.will try it
