I had a problem where my driver side head gasket was leaking so I replaced it and torqued it down to 65 ft lbs with a harbor freight torque wrench.I got the car running and checked for leaks I saw on one corner a small drip leak and the other corner a little more of a drip leak from the gasket this is the same head that was leaking before.I'm planning on getting another torque wrench and checking it to make sure its at 65lbs.So my question is do you think it can be that its not torqued right or what else can I do.
