Head Scan
What Portion of My Brain Is Alive
  • 0%
  • 0-25%
  • 25-50%
  • 50-75%
  • 75-110%
Results are only viewable after voting.
pontiacgp
pontiacgp
Canadian Prime Minister
Mar 31, 2006
24,641
10,068
Kitchener, Ontario
#1
I finally have an appointment for a CT scan of my head. I have been dealing with a sinus or something infection that showed up last May and has not responded to meds so I've dealing with headaches and tinnitus since then. Great medical system we have here as long as you don't need to use it. Anyway, as far as the poll goes I have had 4 major concussions and a few minor ones, plays rugby and a bunch of other contact sports, I have boxed and bounced so took my share of head shots, then there is the alcohol that has killed off a few brains cells. I'm figuring if I have 0 to 25% left I'm doing great...:confused:
C
clean8485
2,327
955
83
Ontario, Canada
#2
Regardless of the percentage Steve, I hope the scan goes well, and that there are no serious issues.
TURNA
TURNA
7,257
9,665
Socialist NY
#3
proxy.php?image=http%3A%2F%2Fwww.tshirtvortex.net%2Fwp-content%2Fuploads%2FHamster-Wheel-Skull-X-Ray-T-Shirt-Tee.jpg&hash=144fd22a1e9dea9ed0a905d2a6a71085
But seriously I hope all is well!
1evilregal
1evilregal
2,542
2,425
Greensboro, NC
#4
owning 3 g-bodies, I often wonder if I need to get my head examined as well....
like Turna and clean said, hope everything goes well.
Jeff L
Jeff L
504
631
Southern AZ
#6
Good luck with the test. Those sinus infections can be brutal and hard to get rid of. Can feel like a vice is twisting your cheeks, forehead, and your upper teeth can hurt like hell too from the infections.
Hope it is nothing serious and never be hesitant to see other doctors if the one you have is not solving your problems.
pontiacgp
pontiacgp
Mar 31, 2006
24,641
10,068
Kitchener, Ontario
#7
went for the CT scan and it is sure alot quieter than the MRI's I have had in the past. The had to redo the scan 3 times before they found any remaining brain matter....:D
C
clean8485
2,327
955
83
Ontario, Canada
#8
Third time lucky? Like I said Steve, I hope it turns out well for you.
airboatgreg
airboatgreg
1,516
1,395
Good luck. I am waiting for results on MRI as I have a fractured lower back and did a upper endoscopy this morning. Sure makes us feel mortal at times. All more reason to have fun and spend more time with friends and family. Best of luck on MRI results
Similar threads
