Head swap question
rogus
300
84
I've had a set of modified (screw in studs,guide plates, 2.02/1.6 valves roller rockers) sbc 441 heads sitting in my garage for a couple years (they worked fine before I set them aside). The car I'm want to put them on is my 76 Chevelle which I generally use to run to the store/daily driver kind of thing. They literally have some dust on them. Is there anything I should with them before I install them other than a quick clean?
86LK
1,712
1,738
were they rebuilt and then set to the side? or did they come off a running engine?
check for surface rust, maybe lube the valve stem guides 🤔
79 USA 1
1,057
2,020
Cheektowaga, New York
I would suggest a set of valve seals, o-ring or umbrella style while they are off the engine. Gives you a chance to also lube the guides and check for wear.
rogus
300
84
They came off a running engine. I had run them before, then my brother bought the engine off me. he decided he was going to run vortecs so I bought the heads back off him. just haven't had the time to install them on my current engine (slightly modified 355/rv style camshaft).
rogus
300
84
ok, thanks. Will check for a shop to get that done. There are just certain things I don't feel comfortable doing myself.
abbey castro
1,016
1,268
Harker Hts TX
Short of a rebuild as suggested by some above, above with seat/guides etc, IMO I would:
1. lap the valves
2. Reassemble with new valve stems and run them.
565bbchevy
9,504
12,381
Michigan
Make sure the valve springs match the cam you're running in the engine you're putting them on
