What do you guys suggest? I know that some people have ran into clearance issues with the crossmember and a/c box with some headers. What are some ones that'll work without any fitment issues?
Geez, Yeah I'm hoping to find a set where I wouldn't have to modify the headers or move the engine. Hopefully some more people will insert their insight too. Thanks though guys.I believe I ran f body headers in mine cant say for sure. but I had to dimple them out by the passage side upper control arm. If you like I can find out exactly what ones I do have in there
I used Flo-tec long tubes. Forgive that I don't have the part # anymore. We had to disconnect the engine mounts and use a bar to lift the engine on one side as the other side header was getting fitted. Took a bit of work but once they were in they were in.
Sure, you can see if you can figure out which ones you have if it wouldn't be too much trouble I meanI believe I ran f body headers in mine cant say for sure. but I had to dimple them out by the passage side upper control arm. If you like I can find out exactly what ones I do have in there
