I know the one guy got lucky just removing the steering shaft cover and Hedman's worked for him. Go with the W/Z repro or Thornton headers with Ram Air Restorations down pipes.I did use olds small block headers on a olds 455 in a g body the problem is the steering shaft hits the header you would have to self clearance that one tube or custom make that tube.
I hope were are talking about a olds 455
and not a buick 455
I think too many of you twats put SBC/LS engines in, now you can't get Olds headers anymore!
What would you want for them I tried finding a set of these as there the most reasonably priced however there defenitly discontinuedI'm not sure if they are still available new but hooker has 2 piece 455 olds g body headers that wrap one tube around the frame. A member here has a set listed in the f/s section. If they are gone I also have a set that is jet hot coated that I would possibly part with.
AAgreed😉
yea they where the arh ones on summit for 1800 cad lol however that’s more then I got into my 455 so I’m really trying to avoid spending that muchI think too many of you twats put SBC/LS engines in, now you can't get Olds headers anymore!
They used to make them. Sadly, I went looking, and came up null (unless you have an LS/SBC...). Try calling Dick Miller, Supercars Unlimited, or Rocket Racing, and see what they say. I assume the $1k models you found were ARH. The owner is an Olds guy, and they're probably the best you'll find.
I was told the sbo headers restrict flow on a bbo did you have any issues ?I did use olds small block headers on a olds 455 in a g body the problem is the steering shaft hits the header you would have to self clearance that one tube or custom make that tube.
and not a buick 455
