Headlight housing
Daca214
647
829
Jupiter, FL
Anyone know what the “official” name of this is and where i can source them?
I tried mikes montes, gbodyparts, and ebay but no luck
Any help would be appreciated
85442/86buick
746
1,118
Perth Country , Ontario
is it the headlight bucket ? that the bulb is secured into with the chrome trim ring .
69hurstolds
8,185
17,568
Here's the deal......
These things have a different part number for ALL FOUR headlamp buckets. There are some on fleabay, used in decent shape, but you must know which one you need. Or if you need all 4.... There's a LH Outer, LH Inner (hibeam), RH outer, RH inner (hibeam)
Give me a minute and I'll drag up some GM part number for you.
Daca214
647
829
Jupiter, FL
Yes i need all 4. And thank you. It figures GM would use all different part numbers :blam:
69hurstolds
8,185
17,568
These aren't cheap cheap, but they're a lot cheaper than NOS. All 4 if this is what you need. Get new trim rings too. Look to be in decent shape....comes out to be about $22 each bucket, which if you buy a new set, they want a couple hundred for just the 4 buckets without trim rings.
http://rover.ebay.com/rover/1/711-5...0001&campid=5335822911&icep_item=362252689114
No rhyme or reason as to how they numbered them...
GM# 5966080 LH OUTER
5966081 RH OUTER
5966082 RH INNER
5966083 LH INNER
Still available from GM for list price of 85.75 EACH!!!! GMpartsdirect.com will sell them to you for 55.87 each. Still....ouch.
Daca214
647
829
Jupiter, FL
check out Rockauto , listed as a headlight assembly.
my 2 cents
So the thing with rock auto is they come with the bulbs as well and each one is like 40 bucks. Im upgrading my headlights to H4 so i dont need the bulb or the rings. Just the back of that assembly.
Daca214
647
829
Jupiter, FL
5966081 RH OUTER
5966082 RH INNER
5966083 LH INNER
Thanks man. And thanks for the part numbers. Im sure this will help others as well
