The clips on the front and rear windsheild will break 99.9% of the time. Everything else ( other than the dome light ) is held in with philips self tapping screws. The pieces of trim over the windows need to be pushed from the inside out to release it from the clips and they almost fall off. Then remove the sill plate, kick panel, Aframe/ Pillar Cover, Seatbelt top anchors, rear seat bottom and back, and rear seat side window trim from the armrest up. Don't forget the press on star clips holding in the dome light and the garment hooks over the side rear windows and then the sunvisors. Almost all the time the headliner board will crack and break at the garmet hooks and the sunvisors. This can easlity be repaired using some matte and fibreglass resin ( I used a $12 boat repair kit from Princess Auto as it had everything ).
Good luck !!! After all that work getting it out and repairing it I took the headboard to an auto uphostery place and it was cheap ( like $50 iirc ) to have them re-do the headliner for me and another $35.00 to have them stich up my visors to match. It would have cost me twice that much between fabric and adhesive to do it myself.
