Garrow215 said:
Any special trick to removing the headrests from an '85 Monte SS?
Don't do the slim jimmy trick with a hacksaw blade or something similar. Yes it works, but it is a PITA and not necessary.
The stem of the headrest has these really big holes in it. The metal sleeve that the headrest stem slides through has a really large spring steel clip in it that pushes against the stem and stops when it hits one of those holes. There is also a plastic sleeve that fits inside the metal sleeve. If you don't have the plastic sleeve because someone removed it, your headrest will wobble and you will have room for the slim jimmy trick. If the plastic sleeve is there like it should be, the stem fits tight and the headrest won't wobble because there isn't any extra room.
All you have to do is wrap your legs around the back rest to hold it tight (tilting the seat back and doing this from the back seat works well), pull out the headrest and wrap your arms around it like you are doing curls...then, very forcefully yet abruptly pull it straight out. The spring steel clip doesn't bend very easily and the tip of the headrest stem is solid with no holes...so it stops there. You won't break anything; just yank it out in a controlled manner, like a man, with a reasonable amount of authority...and don't punch yourself in the face by overdoing it like a brute.
The only way you can break the clip is by forcing the stem when you go to put it back in. Instead of trying to force it, angle it appropriately, and gently hammer down on the headrest repeatedly with your fist. Eventually, it will slip by the clip and you are back in business.
pearlcamino said:
I have the opposite problem, the d/s headrest won't lock in any position and it won't stay in?
Someone broke your clip.
