Heater control valve?
Texas82GP
Just-a-worm
Apr 3, 2015
7,987
18,693
Spring, Texas
Guys,
My 82 Grand Prix was a diesel car when it left the factory. When I bought it, the diesel was long gone and in its place was a 400 SBC and a four speed. Unfortunately the installation of the 400 was a hack job. When I pulled the 400 there was no heater control valve. I'm thinking when I go back together I need to have a heater control valve, especially since I'm in Houston and the efficiency of the air conditioner is important.
From looking at Rock Auto, I see that the diesel would have had the typical Oldsmobile heater control valve that threads into the back passenger corner of the intake manifold. Obviously that's not going to work. I think this one, which is for an 86 Monte with A/C should work.....
My concern is whether I still have the hard vacuum line from inside the car to control this. When I tore my engine compartment down I had two hard vacuum lines from inside the cabin. Both came through the firewall under the A/C case on the passenger side. A pink one and a grey/green one. The pink one was connected to the round plastic vacuum canister next to the accumulator (drier). The other was connected directly to manifold vacuum. My thinking is the pink one is the vacuum source to the HVAC control and the grey/green one should be for the heater control valve. Am I correct or am I all wet?
Anybody have a good picture of an original setup?
Thanks in advance for your thoughts.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
Texas, you're right about the color codes of the plastic vacuum lines....the pink draws and the gray feeds
Texas82GP
Just-a-worm
Apr 3, 2015
7,987
18,693
Spring, Texas
Thanks for the help pontiacgp. Much appreciated.
HAFROD
2,179
3,331
Claremore, OKLAHOMA
I did a search and found this thread. I am getting ready to put this same replacement valve on my Salon and am confused. Which end goes where? It has an arrow for flow but not sure which direction. As it sits in the pic, does the higher port go to the heater core? Basically, does the vacuum port face the firewall/heater core port?
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
the way the heater valve is in the picture is the way it is installed, the nipple for the vacuum port points to the front of the car. It's installed in the smaller heater hose so that's the high pressure side that feeds the heater core
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
It goes dat a way
