Heater core insulation
Rudy913
646
68
New Orleans
What can I use to seal up the part I got covered with a rag?
500/600
1,167
2,638
West Virginia
I'm in the same boat. Originally it was a piece of sorry looking foam. Mine was shot and now I have nothing there since my heater core change.
83StreetMachine
395
819
Central NJ
Any piece of foam you can find will work. You are just going to have to cut to fit.
I've used seat cushion foam, those foam kneel pads they sell at swap meets, and most recently a foam sanding block.
axisg
2,685
2,354
YYZ
I have always used pipe \ duct sealant. It looks like a block of black chewing gum. Electricians and plumbers use it to seal up pipes when they drill thru walls. It won't shrink, or rot. Sealing up the airbox will help the fan blow thru the vents better was well
Reactions: 6 users
57 Handyman
339
389
You can use Just about anything to seal this opening. My suggestion is to go to an AC supply store and ask them for recommendations. When I restored my S-10 several years ago, I used 1.5 x 1/4" AC sealant tape to wrap the opening and tubes.
69hurstolds
8,195
17,596
GM used some sh*tty open cell type foam for the heater tubes, and closed cell foam for the evaporator "seal". Most of the time, the glue holding in the foam around the lower evaporator tube usually would work loose and the fan air pressure would blow it up out of its seat in the housing.
84cutspreme
1,147
152
Hobby Lobby has good stuff and costs $4
abbey castro
1,048
1,318
Harker Hts TX
I used closed cell foam that is used as seal for bottom of doors and garage doors. HD or Low..... has it in rolls.
Reactions: 4 users
