Heater hose flow direction
565bbchevy
9,614
12,683
Michigan
Since there is a flow arrow on this inline valve I just bought I need to know if the smaller hose flows into the heater core.
Turbolq4
1,732
4,207
Nampa Idaho
Just talking out my *ss here, kinda thinking aloud and possibly wrong too. Would make sense to me that the larger hose is going to the heater core while the smaller is headed back to the engine. Heat causing expansion and all.
We now return to your regularly scheduled programming...
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
small hose is the pressure side, large is the return
on the right it's the pressure side, left is return
69hurstolds
8,195
17,596
One time I thought I was wrong but I was mistaken.
Now, that's twice! :) haha
As far as flow......intake manifold connection flows toward the heater core. Heater core flows to the water pump.
69hurstolds
8,195
17,596
:popcorn: Still not convinced it matters.....
It probably doesn't since it's a butterfly valve. Unless it has a check valve in it. But you must do what the arrow tells you to do...or you will die. :)
Reactions: 4 users
