Hei coil
dadep76
100
24
Hi i have a hei coil and the yellow tach wire burned up. The wire from the tach itself to the coil is fine. Any ideas on what would cause that?
Ernest
738
992
Texas
Looks to be aftermarket.... mostly cheap china stuff, but regardless, what brand is it, how old is the coil and by the looks of the wire insulation, too much current flowed through it, like a short inside the coil possibly.
dadep76
100
24
I believe its a bosh. Its only a month old. I knew something was up cause car started to run like crap then stalled out and wouldnt start. I do have an extra ac delco coil but didnt put in.
airboatgreg
2,866
3,114
I am thinking that you have a secondary ignition issue which is causing the coil to draw to much amperage. How does the car run? Does it skip or misfire?
ELCAM
1,120
1,264
If it is a factory tach I would guess it is the filter is going bad. If aftermarket it is the tach going bad.
dadep76
100
24
It did have a little miss then gradually got worse till it stalled and wouldnt start. I put new coil in and ran her and got home and car seemed to wanna run w a miss again.
