MONTE CARLO Hello From Michigan
straturday
16
7
I’ve been lurking this forum for awhile, and figured it was time to finally join! I have an 83 Monte Carlo LS that you could eat off of. I’m getting ready to LS swap it with a freshly rebuilt L76 with Holley swap pan out of a 38k mile G8 GT. I have a 4L80 being built that should be ready any day now (was actually due back a week ago,) and am waiting on my harness, ECM and TCM from Speartech. Once that’s all in, I’m ready to start going!
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,807
Louisville, KY
Welcome aboard from KY from a Cutlass guy in the process of doing final assembly and a LS swap as well. Thanks for the intro, but we NEED pics!!!
straturday
16
7
The first few pics are from when I first found it. It had been sitting on a lift above a vintage Mercedes in a 90-something-year-old guys garage for the pst 20 years.
The last pic is when I got it home and gave her a bath.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,807
Louisville, KY
Very nice man! That Monte has definitely been cared for, and kept out of harsh weather.
How does the frame look? Being a northern car that could make it scary! My '87 Cutlass was originally from up there, I'm the 3rd owner and bought it in 2001. I daily drove mine until 2006ish through alot of rain, harsh winters and no garage. I paid for it when my resto began....new rockers, quarters, roof skin, frame rot repair, broken body bolts, etc. It's now better than new with it's fresh paint, but a long way from finished(are they ever finished?).
straturday
16
7
It’s actually pretty perfect for its age! No frame rust, rockers, fenders and trunk pan are spotless. Interior is 10/10, too!
  • Winner
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,807
Louisville, KY
Sweet! Sitting that long, I'd definitely do a good inspection on all the brake lines, wear parts, etc. Since you seem to be going EFI, then the stock lines should be replaced anyway, then a GN tank if you haven't already got that stuff.
straturday
16
7
Yep, I’ve got a full BPR EFI sending unit and line kit. I’m about to grab a GN tank, I’ve just gotta figure out if I can reuse my filler neck, as Rock is out of the neck.
straturday, welcome to a great site, from here in Bay County, Mich.
Doug
Thank you! I’m in the metro Detroit area.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,807
Louisville, KY
Yes, your filler neck will work...you just have to carefully cut it out of the tank. It's been discussed here plenty as the repop necks tend to have a splash back issue!
I don't have my tank yet, but I went to the junkyard and cut a neck out of a tank with a couple chisels, pry bar, and good tin snips. If you use the search function you will find some topics on the tank/filler necks. Hope this helps.
