Help......403 ac ?
Bri guy
Bri guy
818
I'm trying to figure out how to put my a.c. back on so my belt squeal goes away...i need pics...cant find the right angles online. Any pics would be greatly appreciated. 1977 olds 403
500/600
500/600
801
West Virginia
Don’t do it
olds307 and 403
olds307 and 403
5,842
Melville,Saskatchewan
Bri guy
Bri guy
818
Seems to be the only way to get rid of the squeal....the water pump has the power steering and alternator belt pulling it to the driver side. Having the a.c. back on would spread the pressure.
Reactions: olds307 and 403
olds307 and 403
olds307 and 403
5,842
Do you have the spacers in the right spot?
olds307 and 403
olds307 and 403
5,842
I can find the older A5 compressor diagram but not for the R4.
oldsmobile-307-engine-diagram-307-oldsmobile-engine-diagram-to-her-with-1984-oldsmobile-307-of...jpg
TURNA
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
11,003
Socialist NY
565bbchevy
565bbchevy
7,424
Michigan
If I really had to do this I would probably just fab up a bracket and use something like this idler pulley below just to clean up the engine compartment .
olds307 and 403
olds307 and 403
5,842
I knew I saw it somewhere. I assumed it was the classic olds site. You can run everything on one side but you still need two belts off the crank or it will probably still squeal even without an engine driven fan.
Bri guy
Bri guy
818
[/QUOTE
I took the fan off and no squeal. I didn't drive it but I did rev it a few times and still didn't squeal. So i think i will go the electric fans route. As far as the spacers.....i completely forgot where everything goes. I only took 1 pic and doesn't even help. I didn't think I would be putting it back on. The water pump won't have any negative affect from the current setup?
Thread starter Similar threads Forum Replies Date
78_Monte970 Gas tank too big? Fuel / Air / Boost / Emissions 5
P Need help decoding a 1981 Malibu body tag General Discussion 1
G REGAL 1978 Buick Regal door issue help!! New Users 4
rogus need help with engine id sbc 350 Engine / Swaps / Driveability 4
J MONTE CARLO Wires cut On Torque Converter Lockup. Need help on wiring harness General Discussion 0
A Help with fan & fan clutch Chevrolet Monte Carlo / SS / Malibu 4
Rudy913 Noise help General Discussion 4
T Help Chevrolet Monte Carlo / SS / Malibu 19
P Need help picking rear end!! Transmission / Rear End / Driveline 27
Chuck Cole Need help with my Starter Wires and HEI Plug wire Chevrolet El Camino / GMC Caballero 2
J Help ! New Users 6
T 442 trunk floor pan help Restoration 1
S 84 cutlass drivability help Engine / Swaps / Driveability 1
8 CUTLASS 84 supreme 305 swap (need help) Engine / Swaps / Driveability 27
Dktalee Help finding a HEI non CC Distributor General Discussion 3
N Looking for help buying a 1979 Buick Regal Buick Regal / T-Type / Grand National / GNX 3
P Window sticker help Chevrolet El Camino / GMC Caballero 10
S Speaker help Electrical / Ignition / Starting 0
buick7332 Help with electric trouble Pontiac Grand Prix/Grand Am/LeMans/Bonneville 4
85 El Co Help please! Electrical / Ignition / Starting 12
S Need help locating clip Interior 0
rogus Need help identifying something Interior 13
D 80 Cutlass motor swap help!! Engine / Swaps / Driveability 26
6 WIRE HELP Electrical / Ignition / Starting 7
1320John$$$ Help with mystery Torque converter General Discussion 0
pontiac guy Auburn spider gears - HELP Transmission / Rear End / Driveline 31
pontiac guy 7.5 3 series Auburn posi spider gears- HELP!! Wanted 1
B Transmission help for old guy Transmission / Rear End / Driveline 13
rogus Help with windshield washer pump Electrical / Ignition / Starting 13
Brettbolte MALIBU Paralyzed n need help New Users 13
Happy camper Door hinge help Body / Trim / Paint / Glass 4
Sanchez86Cutlass CUTLASS Need some help with starting issues Electrical / Ignition / Starting 7
Jims442 442 Need help with gas pedal. Engine / Swaps / Driveability 24
M Need Some More Wire Help Updated 4/28 Electrical / Ignition / Starting 16
Pc3 Help with steering column How-To's / Knowledge Base 2
J Need help plz ! G-Body LS Swap 3
bazthespazz '84 A/C Refurb help Cooling / Heating / AC 1
MalibuDavyou5 Malibu Starter Help. Electrical / Ignition / Starting 16
Leon777 Wire id help please!! Electrical / Ignition / Starting 2
M Need help finding this part Body / Trim / Paint / Glass 5
S Help- Looking for Cruise Control Connector or Harness Electrical / Ignition / Starting 4
Jmac 442 1985 Oldsmobile 442 rear glass lower molding help How-To's / Knowledge Base 3
F Carb help! G-Body LS Swap 1
J trying to get help with a 1985 el camino that the windshield wipers wont turn off General Discussion 2
J LED light conversion help General Discussion 4
88MONTESS Eibach help Frame / Chassis / Suspension / Steering 19
T MONTE CARLO need help Electrical / Ignition / Starting 0
R Please help me not screw myself...again OFF TOPIC 22
J Help in identification please. Oldsmobile Cutlass / 442 / Hurst/Olds 28
A Help! Can't find vinyl top moulding for 80' cutlass General Discussion 9
Similar threads
