Hay guys I am quite new to the forum and have some questions
I have a 1985 monte cl, and i want to replace the 4.3 fuel injected with the 305 v8 from the 1987 monte ls i wrecked. I have already taken the 305 out and sold the wrecked body of the 87.. I need to remove the engine in the 85 and drop in the 305.
Where can I find the body motor mounts for the 305???
How can i bypass all that computer stuff left behind in the 85??
Can this be done, if so how??
What else will have to change and how??
Will i need to cut the floor of the 85 to put in the 305 gear shifter, or can i just still use the one on the steering column?? And if so how??
Last one should I keep the 1985 front end, or swap it for the 1987 LS front end which i still have and love???
Thanks TO ALL that HElp
