I don’t quite understand carburetors or heat range on plugs or otherwise that well yet and my motor is modified enough I’m not sure stock specs will work
68 sbo 350 bored .30 over with number 5 heads but unfortunately modern stock replacement cast pistons so dropped compression.
The guess compression is about 7.5:1 it has also been converted to HEI with MSD ready to run distributor.
Right now I’m running the 68 factory recommendation ac Delco plugs with a .45 gap.
I just want to ensure I wouldn’t need to change heat range or gapping due to the HEI, lowered compression and added ethanol in modern fuel.
