Hi All,
I identified a steady stream of oil coming out of the oil pressure switch (threads into the rear of the engine block, with two prong terminals wired to the carb choke). From what I can tell the diaphragm inside failed, and oil is gushing out. When it failed my ‘Choke’ light came on, and oil pressure = 0.
I bought a replacement part and 1-1/16” oil pressure switch socket from the local auto store. I’m having a hell of a time trying to figure out how to remove/unthread this unit? There is not enough vertical space to slip on this socket without hitting the distributor (see photo). Do I have to remove the distributor to unthread this switch? Or just the distributor cap? It’s tight in there please help.
