Hey guys, I’m a newbie to the forum from New York. I have an issue with my 88 cutlass supreme classic brougham. It has the stock 307 5.0 liter V8 with the Quadra jet carb. The engine has an intermittent misfire. It’ll run good for a while then out of no where, the engine begins to stumble, bog out and sometime cut off. Will start right back up with no problem. Every time the engine misfires the check engine flashes. I pulled the codes and I’m getting codes 41 and 42 which leads to the EST Distributor. I replaced the plugs, plug wires, distributor cap and rotor, new ignition coil and infnition control module. Car still doing the same thing with same code. Any input?
