So I started my junk yard motor for the first time today. I figured carb problem s from setting but I never anticipated what happened.
When I cleaned up power steering pump I drained all fluid out. I put new lines on. the car it had been sitting for 18 years with no lines on and had dirt and crud in Port openings. I cleaned those with a rag
When I installed the pump I put the pressure line on and filled pump and took the return line and a vacuum pump and tried to pull good fluid through but could not. And finished installing
So today when the engine fired the steering started turning left in it's own. When it got all the way left it started bogging the pump and about burned the belt.. it turned all new power steering fluid to light tan milky color
I could not turn it back right as long as it was running. I removed the belt and turned the wheels back straight..
Am I looking a pump issue or a gearbox issue. Any leads or what to check would be appreciated.
