Thanks guys im getting there , the fast idle cam was set to high and holding the rmp up to high when i set timing ,now its close im idleing inbetween 8-9 hundered rpm getting down there and timing is staying at the 14 from what the builder recomended with med springs in the distributor, going to mess with it later tonight ,i know my rear end isnt helping right now,i have 229 stock ls,hopefully getting this 373 rear from a guy soon, my set up is 366 dyno'd hp ,turbo 350 built with 2200 stall rpm,full power tops at 5500 ,hei distributor,105 amp alt.625 carter performer carb. Full length large tube headers,2 1/2 in exhaust with cherry bomb welded mufflers, still not seeing the power i would think i should be though ,pretty sure im holding correct fuel pressure ,i have good 8.5 plug wires,a.c delco plugs,seams to loose power mid range , going to work on it tonight and see what happens ,thanks for the posts ill try that tuning and see what happens
