I'm taking off the vinyl top on my 84 Cutlass. How does a person get that foam pad off that's under the vinyl? It's stuck on pretty good!
GotSomeRust said:I'm taking off the vinyl top on my 84 Cutlass. How does a person get that foam pad off that's under the vinyl? It's stuck on pretty good!
a set of windows or just the new chrome trim surround?? i'll be tackling this in a week or so on my project 82, wondering what i'm really gonna be runnin intonycutlass said:u will have to find a set of side windows off a car that dont have a top (like a salon)because the rubber around the crome trim is wider to make up for the spacing that you have by takeing the top off .also for the back window u will need the molding and molding clips too this is easy to install just heat up a flat bar to melt the seal around the window and install the molding clips then reseal it after
