442 (HELP) Window Sweep Installation Problem
Matlock442
n00b
Apr 11, 2018
4
Hello all... I’m new to the forum and looking for some guidance. I recently purchased new sweeps for my ‘87 442 and the windows wont go down far enough for me to get to some of the screws.
I’ve lowered the 10mm window stop and I STILL can’t get to the screws. Am I missing something here? Is there a trick to solving this dilemma?
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,808
Louisville, KY
Hmmm, can you post a couple pics showing the topline of the glass in relation to the sweep?
The windows have to go all the way down to access the screws. If you look across the top inside edge of the door, the steel has little reliefs where each screw is allowing you to go straight in.
I recently put new sweeps on my Cutlass, but the glass was still out. I circled what I mean. If you look at your door you will see what I mean. Sorry, best pic I could find...
Hth,
Scott
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I recently put new sweeps on my Cutlass, but the glass was still out. I circled what I mean. If you look at your door you will see what I mean. Sorry, best pic I could find... View attachment 86696
Hth,
Scott
I changed mine with the windows out and tore one putting the windows in...:(
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,808
Louisville, KY
I could believe that Steve, especially if you don't have a helper to guide the window in. My brother in law and myself teamed up. As I lowered the glass he was pulling the sweeps out to avoid ripping them.
Maverick's_Monte
173
163
Rhode Island
I replaced the sweeps on my Monte recently and I was able to do it with the glass still in the door. The panel on the interior of the door needs to come off. If you have electronic window controls, make sure the glass is down inside the door before removing the panel. With the interior door panel removed, look for an adjustment screw in the cradle that is holding the glass and loosen that screw. This will allow the glass to sink further in the door allowing you access to the sweeps screws. Having a magnet telescoping tool handy is useful just in case you drop a screw inside the door. Also a good time to spray a little wD40, fluid film or or lubricant of choice on the metal inside the door just to prevent any rust issues down the road.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
you're right about that, my impatientism causes me problems....if I could blend my impatientism with my procrastionism I would be more perfect....:cool:
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
I made a tool for this when I did them on my Regal. I'll try to post pics tonight.
motorheadmike
8,976
27,522
84 W40
578
790
This is what I have used for many years. It does make it easier to remove the door panel like others have said.
