I had a few questions I wanted to run by a few of you when it comes to building up my reared it's the original 7.5 in my El camino I kept the rear end from my 94 camaro donor car and am going to swap over the posi and gears into the 7.5 I already have a pair of 28 spline grand national axles to make it all work . Where my question is when it comes to removing everything from the camaro rear end is it as simple as removing brake assembly popping off the diff cover removing bolt c clips and knock out the pin. Than at that point I would slide the axles out and would putting the pin back in keep the unit together and lined up so when I put it into my elky rear end it would come together as simple. And while doing this swap is their any components I might want to replace thank you
