help with A/C control please,,,,,,,,,,,
melloelky
4,154
9,540
mass
i took a page outta UNGN's book on that one..
airboatgreg
2,866
3,114
All good info but go back to basics. Do you have sufficient vacuum to the rotary switch?
olskool
Sep 26, 2021
82
122
33
i honestly don't know about vacuum to the switch. i have my car in my shop doing some minor body work, i have it covered with paper, i am fixing a dent on the fender and i bought a new bumper cover/nose from dixie. i will be painting next weekend and finishing it up, if things go as planned, LOL then i will check the vac. and all the great response and info i have gotten here. thank you all! and if you have any transmission concerns please ask.
mike,,,,,,,,,,,,,,
57 Handyman
339
389
Check to see if you can borrow a vacuum test pump from Autozone. With the motor running and the vacuum tester connected, you'll be able to identify exactly where vacuum exists or doesn't along the route from the motor to the HVAC controls. Start at the vacuum ball and work toward the controls inside the cabin. Our classic cars are old and, more than likely, the vacuum rubber and plastic hoses are dried out, cracked, brittle and in dire need of being replaced. While you may not be able to find colored plastic hoses, a suitable substitute is black plastic hose used for airbags at your local NAPA store. You can also use 5/32" rubber vacuum hose to connect between old and new plastic hoses. Where necessary, I retained the original colored hoses near the controls and any hook up points in order to ease any troubleshooting. Due to the difficulty in threading new plastic hose through the harness opening below the AC box, I opted to retain the original plastic tubes enter the cabin.
Be methodical and patient!
olskool
Sep 26, 2021
82
122
33
thank you brother i will. i didn't get to do the paint on the fender the weather turned nasty here in SC, we are shooting for this weekend. then i will get back on the A/C,,,,,,,,,,,,,
smartinez886
9
5
Im having the same issue with air only coming from the vents and floor. I got all my vacuum lines sorted in the engine bay into the purple hvac line. Im probably going to have to replace the same vacuum selector valve once i test the doors to see if they open.
