85 el camino with a supposed swapped 350 in it. have owned the car for a year, previous owner did alot of shady stuff.
Alright i've been working on these blackjack headers I bought from Summit for the past two days. I'm about done but have run into a problem.
There is an oil switch /pressure unit which connects to the gauge in the dash. Here is a picture of it, I believe with an extension on it that wouldnt normally come on it.
I can not remember which hole on the block this came out of, but there's only a few in the general area I took it from when installing the header (near the oil filter). The hole in this next picture is the only one that would allow clearance for this unit to come off of and clear the header.
I have been trying to thread it into that hole with no luck I think the threads are different and after seeing a hole about 2-3 inches below it right above the flange that would be the end of the block/bell housing area or whatever I believe it came from down there. The problem is that there is NO ROOM at all to mount this thing there. I shined a light up where the flexplate is and I can see through the hole in the picture I just posted, the light shines through. Would this confirm that would not be the right hole for this oil switch? And what is that hole for/ why would it just be open?
The real question though, is what do i do now? Is there a way to remotely mount this? Honestly I have no problem living without the oil pressure gauge...can I just plug this hole? Has anyone else had this problem? Are there any other suggestions in general about this whole install?
It's been frusterating but I'm real close to being done after I finish this. I just want to hear from people with experience with this type of thing.
