Help with under trunk and lower quarter panels
Tony1968
2,319
5,112
NW Indiana
I need some opinions please. My under trunk area where frame mounts are badly rusted through. Pictures below. Until I grind away at lower quarters I won't know how far up the damage goes to there. Can anyone tell me if I should get outer fenders or do they come in smaller patch panels. Also a picture of the kit I have for repairs so far.
Thank you and Merry Christmas to all
Tony1968
2,319
5,112
NW Indiana
Pictures aren't the best but I will get under there again and get better ones as needed
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
What car?
565bbchevy
9,611
12,670
Michigan
Is this expanding foam on the inside of the quarter panel?
  • Scared
565bbchevy
9,611
12,670
Michigan
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,826
Red Deer, Northern Montana territory
Having been in this situation now for a while I understand this dilemma of where to start.
If you buy patch panels, dont plan to use the whole panel. They are not perfect and are not exactly the same. Cut the minimum amount you need from the replacement panel to make the repair to good metal. Use tape to make cut lines and measure 5 times before you cut anything. It's not super hard once you get going on it, just take your time.
Start with a wire wheel or a strip and clean wheel and get to bare metal. Then plan your patches and cuts.
