Help ?!
GaryGBody
n00b
Feb 11, 2017
Is There Any Way Someome Could Give Me Info On My Wiring . I Own A 1984 Cutlass Supreme Someone Swapped It To A 305 And Didn't Wire Everything . There Are Like 6 Wires By The Master Cylinder? I Have No Idea What They Are . Radio Doesn't Work And Heater Doesn't Work Either . I Don't Know Where To Start :(
GaryGBody
n00b
Feb 11, 2017
mr evil
Moderator
Moderator
Aug 4, 2009
857
544
Sooke, BC, Canada
Believe the ones with the black clip are for you wiper motor. Not sure the other 3
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
The other 3 look like fusible links but they should not be there unless someone before you did some wiring for something. I would test those 3 wire for power with the key in accessory and in run. Also if you cleaned them up a bit we can see the colors.
GaryGBody
n00b
Feb 11, 2017
Forgot To Mention Nothing Is On Only Thing That work's Is Break Lights , head lights and tail lights they are ran with a hot hot straight to the battery
Texas82GP
Just-a-worm
Apr 3, 2015
7,987
18,693
Spring, Texas
