Help!!
Gbodynate
29
6
I have a beat up 1982 Monty carlo no rust with a 4.8 l ls with a s475 turbo running 15 lbs of boost car makes decent power car car 3 way adjustable shocks all the way around v6 springs up front car is completely striped out and meroso trick springs in back upper and lower adjustable controle arms 10.5 full drag slicks I have get to use trans break but have one i met up with a guy that (knows g bodys like no one else) ??? Said to put a foot ball in pasenger rear spring add 15 lbs of air and it wpuld fix everything it didn't! I still can't leave on break I still have no traction pinion is set at -2.5 and blows tires off all day every day warm cold what ever tires are maybe 1 year old at most ..... Ummm yeah I think thats it oh of course itbhas a gn rear 8.5 342 gear pleas help I have had countless people tell me countless things nothing that has really helped!
MrSony
6,826
6,730
Des Moines, Iowa
Try an actual air bag in the spring instead of a walmart football.
I've never had a turbo car before... but are you leaving with a lot of boost off the line? Maybe dial it back a bit and let it gradually build up... hopefully someone with more insight will chime in. Looks like you have all the right parts, just need to figure out how to have em all jive together.
Gbodynate
29
6
I am leaving on a vacuum at most 1 lbs I wpuld realy like to leave on 5 or 7 lbs spring pressure or maybe more
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
Sounds like you're leaving too hard for the suspension set up. Try softer springs in the rear. The airbag is only there to counteract the torque twist. It doesn't do a damned thing if the rear of the car is 3ft high in the back. Some pics or videos of the launch would help. Also, a more detailed description of how it leaves and how you drive through it.
lilbowtie
3,460
3,965
Canton Mi
What does the car 1/4 mi (or 1/8th) at and w/ mph?? What converter, is the posi working? With 10.5 slicks you should have plenty of tire, what compound are they? Are you running sway contol? What RPM are you launching at?
L92 OLDS
2,872
3,050
West Michigan
This makes sense to me.
Gbodynate, you didn't mention sway bars. If your suspension is too stiff the rear won't load properly. I run a Hellwig rear sway bar which I like for cornering but it is currently set too tight. Check out the video in my signature. During launch the rear wheels should be forced down.
Gbodynate
29
6
