Hey you, dipsticks
Ribbedroof
Ribbedroof
2,729
2,447
Wellston, OK
#1
So, since it isn't really possible anymore to go pull a dipstick and tube from the self serve yards for a TH350 (nothing that old with drivetrain), I tried an aftermarket one (Pioneer 768023) which is the correct 27" length. Tube fit OK, stick was alittle off on the markings, but the part I can't figure out is that the tab to bolt to the bellhousing was off by around an inch and a half? WTF? the bellhousing pattern on the Chevrolet engine was the same for at least 40 years. How can you F something that simple up?
Looks like I'll be trying to straighten the tube and stick handle that the previous owner mangled after all.
pontiacgp
pontiacgp
Canadian Prime Minister
Mar 31, 2006
24,750
10,212
Kitchener, Ontario
#2
What about moving the tab and welding it in the proper position
olds307 and 403
olds307 and 403
4,380
2,160
Melville,Saskatchewan
#3
The BOP bellhousing pattern requires a Chevy style tab to be bent. I had to do it with my last dual pattern TH350C that came off a sbc 305 Caprice going on an Olds 350. It doesn't make since the aftermarket is usually the other way.
Ribbedroof
Ribbedroof
2,729
2,447
Wellston, OK
#4
What about selling a product that actually fits the application listed?
Yeah, I could, but the whole point was to not have to fabricate something. Might as well fix the one I have if I have to get the torch/welder out
Clutch
Clutch
3,557
5,127
Brick NJ
#5
I went threw 3 different aftermarket dip stick tubes on the square body crew most of the aftermarket ones are junk! One of them was to big for the hole in the trans... Th400 in a square body! Do you get any more common? 73-91 and it wouldn't fit. I ended up getting a locking one from jegs eBay store that fit good but is way to short for that deep of engine compartment but at least it fit
pontiacgp
pontiacgp
Mar 31, 2006
24,750
10,212
Kitchener, Ontario
#6
I agree with you and it would be great if you could actually talk with a real person at the company to ask wtf are they doing selling products that don't fit. I have had junk like that and for me it's less frustrating just to fix the part
TURNA
TURNA
7,472
10,079
Socialist NY
#8
It's not the size of your dipstick that matters, It's how you use it!!!
olds307 and 403
olds307 and 403
4,380
2,160
#9
Just be like Ford: fill it up and plug it!
I had to buy a dipstick for old 2010 Dodge Challenger with the Nag 1 5 spd, just a plug on the end. Our 2017 8 spd has no dipstick that I can see. It is the wave of the future.
TURNA
TURNA
7,472
10,079
Socialist NY
#10
My 2000 Isuzu Rodeo beater is like that no dipstick and the fill hole is on the bottom in the pan!!
and of course it leaks so I am under there once a month!!
