High Beams Galore! No Low Beams
MalibuDavyou5
365
776
Wyoming
I just finished putting on the new passenger side Headlight hoping that it would resolve the issue with the low beams being out when I pull the light on, it doesn't. High beams work like magic though. Relay Switch Issue? If so where it is located?
High Beams on. Low Beams non-existent.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
It sounds like the headlight switch is defective but why not test the switch with a multimeter so you don't take a chance on buying parts you don't need
MalibuDavyou5
365
776
Wyoming
It sounds like the hedlight switch is defective but why not test the switch with a multimeter so you don't take a chance on buying parts you don't need
:cry:, Uggh. before I saw your posting here, I just now went out and checked the switch by turning it a few times from one side to the other. No results. A Multimeter I don't have but I will own next time I head out to Harbor Freight. I went ahead and ordered an AcDelco Switch from Rock Auto. Once I get it in and the car is returned to me after having the Oil Pan Gasket replaced, I will then have to figure out how the old switch comes off. it sits on the left hand side below the Cluster. Thanks for the tool suggestion, going to need it as other problems arise (y).
