If you're mashing the gas and it boggs down but then after a moment comes back and takes off, that would be accelerator pump not working, causing a lean condition that is resolved when the vacuum comes back and pulls fuel through the main jets.
If it stalls and dies, could be too much fuel, which may be due to your excessive fuel pressure.
At take off from a complete stop or a rolling start, it bogs/hesitates/stumbles to accelerate properly... and as long as I'm lightly holding the gas pedal down, things smooth out once it jumps in 2nd gear, but once I come to another stop and accelerate through first gear, the bog/hesitation/stumble happens again. I mashed on the gas once from a complete stop and it stalled.
I reset initial and total timing from 8°BTDC and 36° total to 6° BTDC and and 32° total...bog/hesitation/stumble has bettered.
...and swapped my vacuum hoses around and the acceleration... bog/hesitation/stumble has bettered.
I didn't have this problem until my radiator fan cut open my upper radiator hose shooting rusty water on everything of the engine and my air filter was not attached exposing my open carburetor (haven't cleaned it yet, water killed my last battery and alternator), and swapped my electric fuel pump for a mechanical fuel pump.
