High HP Radiator with factory mounting
64nailhead
Goat Herder
Dec 1, 2014
5,701
12,207
Upstate NY
I'm looking for a radiator that mounts utilizing the factory retainers/mounts and can handle much more than stock HP for a 1/4 mile run. Inquiring for my own car and another car that I'm putting together.
I'm using the cheapest option that I could find, Advanced Auto $80 with discount code single row, and it works great on the street with a 4.8/5.3 combo. At the strip it will make it through the 1/8th without issue, less than 215, but the 2nd 1/8th it will get to 235-238. 230's don't bother me, but it will get turned up soon which I assume will turn up the temps. My son's Cutty with a 421 has been running an Allstar Performance triple pass that is a dual 1" core. It works fabulously and is relatively economical but it won't fit into the mounts because it's a little too tall and the lower hose attachment has to be cut and welded to clear the frame. The Allstar is a good option other than the modifications that are needed.
I'm looking for something that will work that's a direct bolt in. I was looking at the Champion stuff CC162, but I read that they might be overrated. Anyone have any experience with the Champions or with anything else that has worked?
p.s. - I'm not will to drop $500 for a radiator. If it turns to that, then I'll run the Allstar Performance units and have to live with the needed modifications.
Oct 14, 2008
8,822
7,772
Melville,Saskatchewan
The Champion 3 core wasn't big enough for me, with my 8 to 1 403, 195 to 215, 230+ towing probably not for you. A guy on here had the 4 core with a 10 to 1 403, didn't get above 195. It is very wide compared to the 3 core.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,808
Louisville, KY
I'm running the Champion dual pass unit. It fits in the mounts, using the stock V8 top plate, and have yet to see my 5.3 get over 210 on a hot summer day. The model I have is CC162DP.
565bbchevy
9,613
12,678
Michigan
I have the standard CC162 in my 86' Regal and it fit without modifications and keeps my 355 SBC at 180 all day, apparently the only thing it won't cool is a 8-1 403 Olds.
I also have a new clutch fan and 6 blade fan with aluminum blades but will eventually switch to the Intrepid fan set up that I have.
565bbchevy
9,613
12,678
Michigan
64nailhead
Goat Herder
Dec 1, 2014
5,701
12,207
Upstate NY
Scott - I can't use a dual pass due to the location of the turbos - the upper hose interferes.
565bbchevy - now the debate of the 3 or 4 core with small tubes vs double 1" tube core. Do you daily drive your Regal only?
Olds307 - what did you end up using in your 8:1 403?
565bbchevy
9,613
12,678
Michigan
The Regal's 355 is only about a 350 horse engine so no it won't be raced, just a fun cruiser I would drive it when it was nice out and I also drove it two weeks straight to get to work and back and running around etc. in the summer when I blew the trans in my daily driver.
I like big tubes in aluminum radiators and have a Griffen with 2 x 1.25" tubes in my Monte but it is wider and taller and didn't fit without some mods but does a great job at cooling my 565 BBC on the street but I also overkill everything on that car.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,808
Louisville, KY
That makes sense of the clearance issue. It's the same rad as the CC162, just setup for LS inlet/outlet. I'm sure there are some higher HP cars running them with success.
81cutlass
4,647
13,561
Western MN
I have the griffin 8-00010-LS 19*31 (ish) dual pass.
I had to modify the lower supports and build new uppers. I was kinda stuck with finding a dual pass so your non dual pass option opens things up a lot.
It keeps my 6.0 cool, ac on, at the track, in traffic or on the street. Only issues I have had with overheating is on drag weekend is if I'm on 4+hr drives my fuse block would get got and trip my circuit breaker in my electric fan and shut off. If the there isn't airflow driving through a town slow it overheats but if the fan is on it stays cool.
Whatever size the griffin I have is about as big as works. Width and height.
8,822
7,772
Apparently, maybe my 403 was the issue. Exactly why after humming and hawing, I'm not building it. I actually had a 2 core rad with 1" tubes that was a touch too wide that cooled better. I currently have an A body 1 core aluminum plastic rad in the 88. I would personally try the Champion 2 core with 1" tubes, the whole point of an aluminum rad, wider cores for less air flow restriction. I agree, better places I can spend $500.
